I'm guessing that it will be mostly fixes - either new problems in the last update, or issues that were not yet corrected..... I guess we will see.Gotta say the update is pretty quick, I had just turned off the Hopper & 5 minutes later turned on the Joey which was saying it wasn't connected, so I knew something was up - I've never had updates twice in the same week much less 2 nights in a row. Will be interesting to see if anything changes or it's all "under the hood" stuff.
Yeah, just tested. Netflix doesn't do 4K now. But I'm not sure that it is a Netflix to fix problem. From testing yesterday and seeing what was required to get the 4K actually working, I think the scenario was this:netflix app is added to the rest of apps section thanks dish but the problem is on the netflix app there is no ultra4khd yesterday there was ultra4khd on the netflix app and now there is not.i wonder what is going on with it maybe netflix decided to keep working on it.
So you can't move recordings to your EHD? I'm wondering if something is going on with your setup... if it were a "bug" I think it would affect most, if not all. I've moved dozens of programs at a time (it took hours!) with the Hopper 3 without incident (I have 2 EHD's connected at the same). Either your EHD or your Hopper is flaky maybe? Just a thought......Does not appear it fixes the issue of selecting more then 3 or 4 shows to move to EHD never completes.
307 must have been horrible. A lot of my new recordings were corrupted and I got a lot of Error 4 messages.
IYO of course...I just added a second hard drive to my HWSand sent 200 programs to the new drive without a problem. Go back to HWS. it works better.
I got some error 4 messages as well...
Limited time offer
