how does that work ?
used database back up. ended up with 1 file with .ssu on it. is that it ?
thanks
database is for channel list backup with transponders.. will be about 449.kb
application will be the firmware backup and it will be about 3585kb
thanks
so how to get firmware backup on a usb stick ?
thanks
thanksMenu ---> Setup ---> Upgrade and backup --> Upgrade by USB
Make sure it says Application 1 ---> Scroll down below where it says USB0(ROOT)
Then scroll to the right ---> select your backup ----> press OK on remote
then it prompts "Are you sure to upgrade this file?" ---> click OK on remote
Wait til it reboots.
Once you are back on, check firmware for proper upgrade.
setup ---> system information.
thanks
but it sounds like that would be the way to up grade the sw on the x2 box.
i want the firmware off the box to the usb stick.
thanks
still i..haha damn I read it wrong.. well at least now you know how to load it from USB
Here is the X2 to USB
Setup ---> upgrade and backup
Scroll down to Backup to USB
make sure you select Application 1 to backup firmware. (user database for channel list and transponders list)
Scroll down to USB0(ROOT)
Move to the right and click on Add New Files.
Name your backup and save it.
click on the saved backup and it will prompt "Are you sure you want to backup to this file?"
click OK
Done.
still i..
thanks
click OK
Done.
When this is done, does it copies everything into the USB stick, such as the Hardware version, Software version, Date of the update was made, etc, or just a portion.
My receiver should be arriving this coming Monday, and I want to be a little bit informed of what to do.
Thanks.
carlospr43, the attachment 88788 did not worked or downloaded.
We have a factory firmware department.
http://www.satelliteguys.us/downloads.php?do=cat&id=3
It did have a recent bug, but that should have been fixed last week.
Would make it easier to locate various versions.![]()
Press and holt your control key and then hot refresh on that page as it sounds like you have the old closed page stuck in cache.
Limited time offer
