Unplugged over 5 minutes. first screen is download screen. : / Menu button does nothing.
what do you mean download screen?
It shouldnt try and load software until you found the signal (peaked the dish)
The account would be setup and then the receiver activated
The first screen I saw was setting up the remote. but pressing menu at the point did nothing so I setup the remote then it went to searching for the receiver update.yes that is weird. Like I say normally the 1st screen you'd see (if the receiver was in a virgin state) is the point dish screen. Then after the dish is aimed you select "OK" and it does a check switch, then downloads new software and gets you to the "receiver not activated...call to activate" and has the R & S#'s on the screen
Once its activated then you can get into the menus
its acquiring a signal now after the check switch. I can see PPV's earlier. I think I have the 72.7 lnb on 61.5. So if I do I should turn the dish to the right to find 72.7 correct?run a check switch and see what happens
Signal wise should be in the 40's or 50's at minimum. While the dish meter goes to 125 the highest on Eastern arc is 60's.....
Moved it to the right a bit got a 60 signal. I think I have it aimed now.Thanks to all.
Now to figure out how to use this receiver. I got the cheap package for now. I think it was $14.99 a month. No commitment.
Glad to hear ya got it going.
I started to mention earlier that it was possible that the receiver was already getting a signal and thats why it went to the update instead of allowing you into the menu.
Limited time offer
