Only problem experienced so far is trying to save a newly created list to .si file type from an imported file.
This editor would be especially useful if it could import an openbox channel list, convert it to MicroHD without too many issues, then save in MicroHD format.
This workaround worked when importing either the provided sample file or my actual Openbox data....After importing a file, delete the Channel list and the Provider list then perform the same file import a 2nd time. The second time the import is performed the Service Provider list propagates correctly...
glad you folks are working out the kinks while i am waiting for my microhd. pins and needles... charlie
Limited time offer
