A manual timer is one that allows you to record a specific channel at any specified time, for as long as you want it to. This is not program specific, it is channel, time, and length specific.....
You know you can still go to the channel and record manually right?
Define manual timer? I don't have issues recording things. Can you give an example of what you would like to do?
What do you mean?
On Sirius channels.. there's no programming listing. So if you want to record something, you have to record the whole 8-hour block... same thing with OTA sub-channels that don't have program information.
Tampa8 said:Just to be clear to everyone, one of the biggest advantages of a true Manual Timer is when the program does not exist yet. Two months from now it's announced a new series is starting and it's on a channel you may not watch often. You are afraid you will forget about the program by the time it comes. A Manual timer allows you to pick any date channel and time in the future, beyond the guide, as well as length and set it to record. It has astonished me the newer receivers don't do this.
That's what the DISH PASS/Seek & Record timers are for.
Sent from my DROIDX
So they will record a show that does not exist yet??
We had a manual timer on our 722 set up to record CNN each night for one hour midnight to 1am Monday thru Friday. We needed to do this to record the Piers Morgan program for my wife because all three of our timers were busy when the orginal broadcast of Pier's program happened during prime time. This worked out well and we miss being able to do this with our Hopper/Joey system.
Yes in principle, but if you don't know or spell the name wrong or just know part of the name it won't find it, even with exact unchecked. Try Mcoy and see if Hatfield and Mcoys show up. Worse, it won't work for any OTA subchannel with no guide info. Dish Pass works great for finding shows no matter where they are assuming you know enough correct info, but as a manual timer it's just ok useless for OTA as described.
I see Hat didn't find it either....
A Monday-Friday timer (or daily because Friday night is Saturday) will solve that.
Thats what we had set up with our 722 but so far haven't found that feature with the Hopper.
True I got lots of "Hats" I set the timer, looked when Hatfield/Mcoy was on and it was not set to record. Didn't try adding F. I'm certainly not claiming it won't work at all, it will, but for some with spelling problems or not putting in enough letters, you may not get what you are looking for.I don't know, I just tried it. When I put 'Hat' in the Search field, I came up with quite a few 'Hat's.
Just go to the next "Piers Morgan" listing on the guide, click it, click "Record Series Timer," by "Episodes" choose "Mon-Fri" or "Daily."
Limited time offer
