RG-6 is only needed where there are relatively high currents in the cable. Unless they're planning on powering the XiP110 through the cable, I don't expect this to be the case.Would it need to be RG-6 atleast to the main?
No, it has ONE output
http://www.satelliteguys.us/attachment.php?attachmentid=64896&d=1304659742You are right except that the 813 has 4 outputs. That is why I prefer 843.
harshness said:RG-6 is only needed where there are relatively high currents in the cable. Unless they're planning on powering the XiP110 through the cable, I don't expect this to be the case.
True, but I disagree with this misleading count. The Home Video output doesn't exist on any other Dish receiver, so comparing it (or the back panels) to Dish Duo receivers is not very illuminating. Can you get independent HD output to 3 (and possibly 4) TVs? I believe the answer is "Yes". Therefore, it should be called an 833 or 843, depending upon whether we can address the local output independently from the rest.What is meant.. is that the 813 only has outputs for "TV1" on it. If you look on the back, all outputs are dedicated to 1 TV not like on a 922, or 722 which has outputs labeled for TV1 and TV2 on the back of the receiver.
Did you not bother to read ANY of the previous thread before you posted? If you had, you should have understood the back of the 813 clearly has outputs ... 3 of them ... for direct connection to a television. At arguement *this* late in game is a minor squabble over what you'd label an output in terms of out to a TV ...Is the 813 capable of output, or will we need a 110 at "all" locations, meaning for 3 TVs, 3 110's, or will we be able to do 2 110's and the 813?
I see what you're getting at... but I'd modify what you're thinking.. while the Home Video Network is an output.. you cannot hook a television directly to that output ... that output *must* go to a special splitter/switch, for distribution to a 110 box, and THEN it can go to a TV. Every other box to date, and usually when we think of "outputs" we mean for direct connection to a television.. composite, compoent, coax, hdmi ...True, but I disagree with this misleading count. The Home Video output doesn't exist on any other Dish receiver, so comparing it (or the back panels) to Dish Duo receivers is not very illuminating. Can you get independent HD output to 3 (and possibly 4) TVs? I believe the answer is "Yes". Therefore, it should be called an 833 or 843, depending upon whether we can address the local output independently from the rest.
Ok.. so roll with it.. if you have a limit of 10 110 thin clients, then you have an 8103? yeah.. THATS great.. start over with 1960's technology names..Well, the key IMHO is not the number of connections on the back, regardless of what they can be used for. The key is the number of independent feeds, over whatever medium that works, that eventually can be displayed on a TV. We have read in this thread (or the questions/answers thread) is that, unlike existing receivers, the tuner inputs on an 813 are not hardwired to a particular output. But I have no idea how complete this flexibility is... Suppose the 813 has a Sling Adapter AND a USB ATSC tuner connected. Suppose furthermore that the user of the Sling Adapter is watching a recorded program. Can 4 TVs still watch 4 different live programs, as long as one is OTA?
I sayeth that you and Dish think alike.series 8 ... 1 tv (supported & directly connected), and 3 tuners..
722k ... 7 series ... 2 TV's, and 2 tuners (base)...
what sayeth you?
I think it starts with an 8 because it's better than a 722, but it doesn't have sling built-in like the 922.
Sent from my iPod touch using SatelliteGuys
Lets just hope they never come out with an "11" somethingI think it starts with an 8 because it's better than a 722, but it doesn't have sling built-in like the 922.
Question for those paying attention: what was the 922 called during development?
I remember them calling it the 722s.
With the blockbuster acquisition will there be some type of possible instant steaming with dish recievers
Limited time offer
