Is there any way I can configure my equipment to use 72 instead of 77 while the Louisville HD channels are there?
I am in Oldham CO and can tell you that the PQ Thur my cheap antenna kills the PQ from dish For wave3, whas 11, Wlky 32 and WDRB 41.
I would buy an antenna![]()
I currently have a 40 mast with an aerial, but have a big hill just across the drive right in the path to the broadcast towers in the knobs. I have gotten signal from them in the past, but it is never consistent. I currently have the antenna pointed north.
Darn hill!
What kind of dish setup do you have? (61.5,72,77)
I have a Western Arc setup and a Wing on 77 for QCA HD Locals. When the locals went out on Sunday, I assumed my dish got bumped or something, so I went out and started messing with it. Then I got on here and realized it wasn't my dish at all. But since I was already probably off the 77 signal (because I was moving the dish), yesterday I moved the wing from 77 to 72 (my dish is pretty easy to access). The one wierd thing though, when I moved the dish to 72, my signal meter showed it as 77 still. I ran a Check Switch test, and it installed 72 as the Wing in place of 77. But on the Signal Meter screen, with satellite 72 selected, it still said "Locked - Wrong Sat - Echostar 77" or whatever the message is. So the Signal Meter thought it was 77, but the Switch Test knew it was 72. Exited out, downloaded a Guide, and have my HD locals back until they get moved back.
Whenever they switch them back to 77, I'll have to do it again, but thought since I was most likely already off 77 in the first place, figured I'd get it fixed for the time being.
My installation summary shows 110, 119, & 129 (used to show 77 before my last check switch). I believe I have a Dish 500 pointed at the western arc with a wing pointed at 77. I am considering pointing the wing to 72 per aaronwt6's suggestion. Someone earlier in this thread or another one said that the wing should see both of them becaulse they are in the eastern arc, but I don't see 72 when I do a check switch.
Looks like you have 1k2 dish(110/119/129) w/ a wing dish from what you have shown us here. You might want to talk to one of the E* people here about being migrated to EA using a 1k4 dish.
Wouldn't Ecostar or Dish need to file an SEC document if the bird was messed up?
I would have to guess that it depends on the actual issue. If it's fixable, no need to file or report anything, wouldn't you agree ?Wouldn't Ecostar or Dish need to file an SEC document if the bird was messed up?
Limited time offer
