Just a thought will it sit on top of the hr24 like it does on other receiver's ?
I dont think so.
DIRECTV Black Satellite Off-Air Tuner - AM21
What are you saying ?
It fits perfectly as your picture shows.
I dont think so.
The photo is not of the HR24. Not sure if there is a size difference but if there is this unit may be a little larger than the 24.
AM21 is slightly large for the HR24, but is fine underneath it.
Maybe someday we'll see an AM24, but doubtful.
Why are people paying $59 or $69 for AM21? DirecTV sells them for $50 shipped. If you call they may even discount it or give you a credit or something. You can also order online in the equipmnet page on your account. You have to have an HR21 or higher before the order option is there, so if you're upgrading from only HR20's you'll have to activate something else before the option is there.
Temp is staying 109-111 in open living room ent center
this morning mine showed 108f![]()
Just ordered one from Solid Signal it does say that I won't need my B-band converters anymore is that right?
Built in
Just got mine. Its a beauty! One problem though. I have recordings on my hr21 that we really want to see. If I deactivate the hr21, would I still be able to watch the recordings?
I don't have an external drive though. If I can't then I might have to wait before I activate the hr24. Damn!!!!
Limited time offer
