Note the just like Satellite Guys has a higher percentage of AEP and multiple Duo receiver subs, it also has a higher percentage of early HD adopters who would have 61.5/110/119.
Can't do it because I am the only one with a mpeg 4 612 DVR. Everyone else has cruddy SD sets with 3 cruddy 510 DVR's. My mother would not give up that receiver for anything and she can never go back to not using a DVR.
Not always ,Dish sometimes hides the channels from non subscribers, but I should still at least see them as 'red' channels, right?
Probably not, since you can't see the bird....I have a 110/119/61.5 setup that was installed for me 2 years ago when I upgraded to HD. The channels are not appearing in my guide at all. I'm grandfathered in to the Turbo HD Bronze (HD only) package, but I should still at least see them as 'red' channels, right?
Installer just came and said he could not do anything because Im not able to get the 129 satellite. What about the eastern arc??
Yankeefan,
As long as you currently have a 61.5 Dish it could be replaced with an Eastern Arc dish, you will also need the Dish 500 pointed at 110. The installer will have to run a cable from the 110 output of the Dish 500 to the Eastern Arc Dish. He might have to replace the LNB, with a Single slot DP LNB with an "I" adapter for the Mounting arm.
John
Thank you for the help but the installer said nothing about that setup and has already left he said I have to wait untill they are put onto the 61.5. I dont know what to do now. He didnt act like he knew anything!!
Limited time offer
