2/10/2010 2:07pm - Uplink Activity Report - 97 changes | SatelliteGuys.US
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 2/10/2010 2:07pm - 97 changes
Uplink Comparison Range: 02/10/2010 01:51P - 02/10/2010 02:06P
Channel Additions:
6530(9) - KAIT [MPEG2 SD 8PSK] added to Ciel-2 129W TP 12 Spotbeam 30 (NA)(Jonesboro, AR-ABC)
6534(20) - KTEJ [MPEG2 SD 8PSK] added to Ciel-2 129W TP 12 Spotbeam 30 (NA)(Jonesboro, AR-PBS)
6535(48) - KVTJ [MPEG2 SD 8PSK] added to Ciel-2 129W TP 12 Spotbeam 30 (NA)(Jonesboro, AR-N/A)
8873(41) - WJAN [MPEG4 SD] added to EchoStar8 77W TP 08 ConUS beam (NA)(Miami, FL-IND)
6521(8) - WAGM [MPEG2 SD] added to EchoStar10 110W TP 25 Spotbeam 08 (NA)(Presque Isle, ME-CBS)
6524(10) - WMEM [MPEG2 SD] added to EchoStar10 110W TP 23 Spotbeam 08 (NA)(Presque Isle, ME-PBS)
6531(11) - WBKB [MPEG2 SD 8PSK] added to Ciel-2 129W TP 11 Spotbeam 22 (NA)(Alpena, MI-CBS)
6534(6) - WCML [MPEG2 SD 8PSK] added to Ciel-2 129W TP 11 Spotbeam 22 (NA)(Alpena, MI-PBS)
6531(12) - KEYC [MPEG2 SD] added to EchoStar10 110W TP 12 Spotbeam 28 (NA)(Mankato, MN-CBS)
6530(2) - KQTV [MPEG2 SD] added to Ciel-2 129W TP 08 Spotbeam 29 (NA)(St.joseph, MO-ABC)
6531(5) - KXGN [MPEG2 SD] added to EchoStar10 110W TP 26 Spotbeam 33 (NA)(Glendive, MT-CBS)
6540(7) - WBBJ [MPEG2 SD] added to EchoStar10 110W TP 20 Spotbeam 14 (NA)(Jackson, TN-ABC)
6543(16) - WJKT [MPEG2 SD] added to EchoStar10 110W TP 20 Spotbeam 14 (NA)(Jackson, TN-FOX)
6544(11) - WLJT [MPEG2 SD] added to EchoStar10 110W TP 20 Spotbeam 14 (NA)(Lexington, TN-PBS)
6532(15) - WTAP [MPEG2 SD] added to Ciel-2 129W TP 06 Spotbeam 25 (NA)(Parkersburg, WV-NBC)
620 - HUMTV [MPEG2 SD] added to Anik F3 118.7W TP 28 ConUS beam (NA)
623 - MSALA [MPEG2 SD] added to Anik F3 118.7W TP 26 ConUS beam (NA)
4800 - TMP30 [MPEG4 HD] added to Nimiq5 72.7W TP 28 ConUS beam (NA)
4801 - TMP31 [MPEG4 HD] added to Nimiq5 72.7W TP 28 ConUS beam (NA)
4803 - TMP33 [MPEG4 HD] added to EchoStar11 110W TP 07 ConUS beam (NA)
4803 - TMP33 [MPEG4 HD] added to Nimiq5 72.7W TP 32 ConUS beam (NA)
4804 - TMP34 [MPEG4 HD] added to EchoStar11 110W TP 07 ConUS beam (NA)
4804 - TMP34 [MPEG4 HD] added to Nimiq5 72.7W TP 32 ConUS beam (NA)
4807 - TMP37 [MPEG4 HD] added to Ciel-2 129W TP 32 ConUS beam (NA)
4807 - TMP37 [MPEG4 HD] added to Nimiq5 72.7W TP 06 ConUS beam (NA)
4808 - TMP38 [MPEG4 HD] added to Ciel-2 129W TP 32 ConUS beam (NA)
4808 - TMP38 [MPEG4 HD] added to Nimiq5 72.7W TP 06 ConUS beam (NA)
4809 - TMP39 [MPEG4 HD] added to Ciel-2 129W TP 32 ConUS beam (NA)
4809 - TMP39 [MPEG4 HD] added to Nimiq5 72.7W TP 06 ConUS beam (NA)
4810 - TMP40 [MPEG4 HD] added to Ciel-2 129W TP 32 ConUS beam (NA)
4810 - TMP40 [MPEG4 HD] added to Nimiq5 72.7W TP 06 ConUS beam (NA)
4811 - TMP41 [MPEG4 HD] added to Ciel-2 129W TP 32 ConUS beam (NA)
4811 - TMP41 [MPEG4 HD] added to Nimiq5 72.7W TP 06 ConUS beam (NA)
4812 - TMP42 [MPEG4 HD] added to Ciel-2 129W TP 32 ConUS beam (NA)
4812 - TMP42 [MPEG4 HD] added to Nimiq5 72.7W TP 06 ConUS beam (NA)
4813 - TMP43 [MPEG4 HD] added to Ciel-2 129W TP 32 ConUS beam (NA)
4813 - TMP43 [MPEG4 HD] added to Nimiq5 72.7W TP 06 ConUS beam (NA)
4814 - TMP44 [MPEG4 HD] added to Ciel-2 129W TP 32 ConUS beam (NA)
4814 - TMP44 [MPEG4 HD] added to Nimiq5 72.7W TP 06 ConUS beam (NA)
6523(16) - WAGMD [MPEG2 SD] added to EchoStar10 110W TP 25 Spotbeam 08 (NA)
6533(13) - WBKBD [MPEG2 SD 8PSK] added to Ciel-2 129W TP 11 Spotbeam 22 (NA)
6533(38) - KEYCD [MPEG2 SD] added to EchoStar10 110W TP 12 Spotbeam 28 (NA)
6533(49) - WTAPD [MPEG2 SD] added to Ciel-2 129W TP 06 Spotbeam 25 (NA)
Channel Package Flag Changes:
285 - SMC [MPEG2 SD] - EchoStar11 110W TP 16 ConUS beam changed to Available
285 - SMC [MPEG4 SD] - Nimiq5 72.7W TP 09 ConUS beam changed to Available
550 - OLYM1 [MPEG2 SD] - EchoStar11 110W TP 24 ConUS beam changed to Available
550 - OLYM1 [MPEG4 SD] - Nimiq5 72.7W TP 29 ConUS beam changed to Available
551 - OLYM2 [MPEG2 SD] - EchoStar7 119W TP 18 ConUS beam changed to Available
551 - OLYM2 [MPEG4 SD] - Nimiq5 72.7W TP 29 ConUS beam changed to Available
552 - OLYM3 [MPEG2 SD] - EchoStar7 119W TP 18 ConUS beam changed to Available
552 - OLYM3 [MPEG4 SD] - Nimiq5 72.7W TP 29 ConUS beam changed to Available
4933(387) - CI [MPEG4 HD] - EchoStar11 110W TP 19 ConUS beam changed to Available (H)
4934(239) - WGN [MPEG4 HD] - EchoStar11 110W TP 19 ConUS beam changed to Available (H)
4935(194) - GREEN [MPEG4 HD] - EchoStar11 110W TP 19 ConUS beam changed to Available (H)
19222 - IWINO [DATA] - EchoStar7 119W TP 13 ConUS beam changed package flags (A)
Channel Renames:
363 - TMP15 - Ciel-2 129W TP 18 ConUS beam renamed to INDIE (A)
363 - TMP15 - Nimiq5 72.7W TP 32 ConUS beam renamed to INDIE (A)
365 - TMP14 - Ciel-2 129W TP 18 ConUS beam renamed to RETRO (A)
365 - TMP14 - Nimiq5 72.7W TP 32 ConUS beam renamed to RETRO (A)
710 - ICBLE - Anik F3 118.7W TP 25 ConUS beam renamed to ETFIN (A) (H)
4114(114) - TMP59 - Ciel-2 129W TP 20 ConUS beam renamed to E! (A) (H)
4114(114) - TMP59 - Nimiq5 72.7W TP 03 ConUS beam renamed to E! (A) (H)
4135(135) - TMP64 - Ciel-2 129W TP 20 ConUS beam renamed to BBCA (A) (H)
4135(135) - TMP64 - Nimiq5 72.7W TP 03 ConUS beam renamed to BBCA (A) (H)
4149(149) - TMP62 - Ciel-2 129W TP 20 ConUS beam renamed to FSC (A) (H)
4149(149) - TMP62 - Nimiq5 72.7W TP 03 ConUS beam renamed to FSC (A) (H)
4185(185) - TMP60 - Ciel-2 129W TP 20 ConUS beam renamed to HLMRK (A) (H)
4185(185) - TMP60 - Nimiq5 72.7W TP 03 ConUS beam renamed to HLMRK (A) (H)
4204(204) - TMP10 - Ciel-2 129W TP 23 ConUS beam renamed to TRU (A) (H)
4204(204) - TMP10 - Nimiq5 72.7W TP 32 ConUS beam renamed to TRU (A) (H)
5306 - TMP62 - Ciel-2 129W TP 20 ConUS beam renamed to FSC (A) (H)
5306 - TMP62 - Nimiq5 72.7W TP 03 ConUS beam renamed to FSC (A) (H)
5308 - TMP64 - Ciel-2 129W TP 20 ConUS beam renamed to BBCA (A) (H)
5308 - TMP64 - Nimiq5 72.7W TP 03 ConUS beam renamed to BBCA (A) (H)
5322 - TMP59 - Ciel-2 129W TP 20 ConUS beam renamed to E! (A) (H)
5322 - TMP59 - Nimiq5 72.7W TP 03 ConUS beam renamed to E! (A) (H)
5326 - TMP60 - Ciel-2 129W TP 20 ConUS beam renamed to HLMRK (A) (H)
5326 - TMP60 - Nimiq5 72.7W TP 03 ConUS beam renamed to HLMRK (A) (H)
5373 - TMP15 - Ciel-2 129W TP 18 ConUS beam renamed to INDIE (A) (H)
5373 - TMP15 - Nimiq5 72.7W TP 32 ConUS beam renamed to INDIE (A) (H)
5374 - TMP14 - Ciel-2 129W TP 18 ConUS beam renamed to RETRO (A) (H)
5374 - TMP14 - Nimiq5 72.7W TP 32 ConUS beam renamed to RETRO (A) (H)
9430(204) - TMP10 - Ciel-2 129W TP 23 ConUS beam renamed to TRU (A)
9430(204) - TMP10 - Nimiq5 72.7W TP 32 ConUS beam renamed to TRU (A)
9450(135) - TMP64 - Ciel-2 129W TP 20 ConUS beam renamed to BBCA (A)
9450(135) - TMP64 - Nimiq5 72.7W TP 03 ConUS beam renamed to BBCA (A)
9474(114) - TMP59 - Ciel-2 129W TP 20 ConUS beam renamed to E! (A)
9474(114) - TMP59 - Nimiq5 72.7W TP 03 ConUS beam renamed to E! (A)
9482(185) - TMP60 - Ciel-2 129W TP 20 ConUS beam renamed to HLMRK (A)
9482(185) - TMP60 - Nimiq5 72.7W TP 03 ConUS beam renamed to HLMRK (A)
9483(285) - TMP61 - Ciel-2 129W TP 20 ConUS beam renamed to SMC (A)
9483(285) - TMP61 - Nimiq5 72.7W TP 03 ConUS beam renamed to SMC (A)
9512(319) - TMP58 - Ciel-2 129W TP 20 ConUS beam renamed to SHO-W (A)
9512(319) - TMP58 - Nimiq5 72.7W TP 03 ConUS beam renamed to SHO-W (A)
9520(149) - TMP62 - Ciel-2 129W TP 20 ConUS beam renamed to FSC (A)
9520(149) - TMP62 - Nimiq5 72.7W TP 03 ConUS beam renamed to FSC (A)
Transponder Changes:
Ciel-2 129W TP 08 Spotbeam 29 changed from 21500 8PSK 2/3 to 20000 QPSK 5/6
Channels in the system: 6753
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Looks like they are filling in the rest of the markets they didn't cover before since the market only had 2 or 3 locals channels of the big 4. Prepping to cover them all so they can bring in out of markets again to fill the markets that missing local channels.
PQ on BBCA-HD is incredible right now. Anyone know if this channel is full 1920x1080 or the standard 1440x1080?
Either way the PQ of the show, I think it's Antiques Roadshow, is unreal.
Dumb question. I'm guessing these channels are special temporary channels NBC is using for the Olympics?
Any word on Turbo HD subs getting any of these channels? Anyone at home with Turbo that can check and update ...
I have TurboHD/Dish America Silver and see all the channels in RED. So, unfortunately, its a no go. How about you absolute subscribers?
I'd happily pay $5.99 for the multisport pack if I could get access to FSC HD.
The commercial for the BBC News was in HD, so we can probably assume that it is in HD :up
Where is the uplink?
D
2/12/2010 5:16pm - Uplink Activity Report - 2 changes
