HR2x R22 CE Release 6/12 & 6/13 v.0x323 | SatelliteGuys.US
dfergie
Proud Staff Member
Staff member
HERE TO HELP YOU!
PLEASE READ THIS FIRST! DirecTV Cutting Edge Program: Terms, FAQ, How-To, Hidden Features, and More
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue :)
For the latest updates, check out the Satelliteguys CE Chat on Friday nights:
chat.satelliteguys.us
HR20-100, HR20-700
HR21-100, HR21-200, HR21-700
HR22-100
HR23-700
R22-100, R22-200
Friday 6/12/2009 11pm - 2:30am ET
Saturday 6/13/2009 11pm - 2:30am ET
Improvements & Updates
* DIRECTV Cinema marquee (channel 1100), even for those without internet
setup
* Play DIRECTV Cinema on-demand from program guide movie posters (try
the movie posters in the 1000's)
* Parental Controls touch ups
* MRV touch ups
* DoublePlay touch ups
* History information
* Under the hood
Notes
* No keyword needed for DoublePlay
* Multi-Room-Video activated with keyword "MRVCLIENTON"
* You will lose your guide cache when reverting from CE to national
* High Risk Download
* When reporting issues with 1080p, please include the TV resolution
information reported from the Miscellaneous Options screen as well as
your TV model number
Previous Release Information:
New features
01 - Multi-Room Viewing (enable with keyword search "MRVCLIENTON")
01 - Faster Reboots
03 - Dual Live Buffers (no longer requires keyword search to activate)
Improved/Updated
01 - Program Guide refinements
01 - Under the hood
01 - UI polishing
01 - 20 actors available again in listing
01 - Faster Guide
02 - DIRECTV On Demand in native mode
02 - Playlist sorting
02 - Prioritizer deletion
02 - Previous channel when exiting interactive
02 - Under the hood
03 - Fixed frequent rebooting introduced in CE:20:02
03 - Missing OTA Channels
03 - No Guide Data HR21-200 only
03 - MediaShare: Tversity subfolder playback
03 - Under the hood
04 - Fixed long time to get out of standby
04 - Dual Live Buffers (GameSwap)
----- Resolution issues when switching buffers
----- Scheduled recordings will default to background tuner when there is no response to conflict resolution dialog
----- New information message when activating
----- Deactivates after 2 hours of non-use
----- Deactivates by putting receiver in standby (turn off) for 5 minutes or more and then turn it back on
----- Removed Toggle Tuner menu from TV Options (Yellow Button)
04 - Reboot issues
04 - Black Screen
04 - Under the hood
05 - Receivers not getting software download
05 - Keep or Delete OSD upon playback
05 - DoublePlay: Channel banner display
05 - MediaShare: Unable to play videos
05 - Reboot issues
05 - Caller ID
05 - Record Series Conflict screen
05 - System Test
05 - Under the hood
06 - Trickplay to Normal Play speed
06 - No Audio on Local channel recording
06 - Audio on Mix channels
06 - MediaShare compatibility with media servers
06 - History and To Do List recording messages
06 - Record Series confirmation messages
06 - Booking live program recording prompts to add end time extension
06 - 1080p/24 TV compatibility
06 - Under the hood
07 - Spontaneous reboots
07 - Box unable to boot after CE download
07 - Lost audio after CE download
07 - Play button activates trickplay bar in ScoreGuide channels
07 - To Do List and History info screens
07 - MRV client playing back ATSC recordings
07 - DoublePlay after exiting recording
07 - Loss of background in interactive apps
07 - Under the hood
08 - MRV touch ups
08 - Playlist deletions upon software update
08 - GameSearch improvements
08 - Trickplay bar display
08 - Under the hood
09 - MRV touch ups
09 - Live Extension touch ups
09 - MediaShare fixes
09 - Incorrect title in Playlist
09 - Audio selection on ATSC channels
09 - To Do List information
09 - Under the hood
Download went fine but kind of confused on these 2 notes:
setup
When I tuned to 1100 it says not available.
Also not sure on the whole thing about "program guide movie posters" deal means
So far don't find anything broken
MRV not working with my D-Link wired router
I'm getting the "Cannot play DTCP content. AKE failed". Just tried CE s/w 0x323 for first time and everything seems to work except MRV. I entered the keyword search options on both receivers and get the merged playback list with sort and delete options but no shared playback from either receiver. I tried to use the "Network Services" feature under setup but it will not "Connect successfully" in auto or manual mode after successfully starting network services. Is the failure to connect to network services my problem? Any suggestions on how to manually setup D-Link wired router? I did some browsing in D-Link help section and it suggested using the "Virtual Server" or "Port Forwarding" features. The D-Link Virtual Server setup is asking for a lot of info: "Public port, Private port, Protocol (UDP, TCP or both). I have two HR22-100's; any suggestions? Thanks!
Update: got it fixed with mrvclientoff/mrvclienton/iamanedgecutter/restart...also moved one ethernet cable from router and connected directly to other dvr.
See this thread: http://www.satelliteguys.us/directv-cutting-edge-ce-discussion-forum/178278-need-help-mrv.html
So what does everyone think of MRV appearing on the one List vs choosing a DVR when the List button is pressed? Just curious. Sorry if I missed this discussion. I have been very busy this past week.
So far this CE has been working pretty good here. Unfortunatly for now I don't have a second HR unit so I can't comment on MVR but everything else seems snappy and nothing seems broken this round. Media sharing seems to actually be working a bit better even, at least for me. Thats a plus
DirecTV TVApps (formerly widgets) now public beta
D11-800 CE Release 6/19 v.1188
