4/21/2009 2:26am - Uplink Activity Report - 12 changes | SatelliteGuys.US
JohnH
Godfather of the Uplink Reports
3,013
Kansas City, Missouri
UPLINK ACTIVITY: SAMPLE TAKEN 04-21-2009 03:01:59 TO 04-21-2009 03:03:05 ET
4 ADD(S)
ADD 5200 WSET{LYNCHBURG, VA} MPEG4 HD TID 4575 Tp 5 SPOT 39 Ciel 2 129w UNAVAIL HIDE MAP-C 13
ADD 5201 WDBJ{ROANOKE, VA} MPEG4 HD TID 4575 Tp 5 SPOT 39 Ciel 2 129w UNAVAIL HIDE MAP-C 7
ADD 5202 WSLS{ROANOKE, VA} MPEG4 HD TID 4575 Tp 5 SPOT 39 Ciel 2 129w UNAVAIL HIDE MAP-C 10
ADD 5203 WFXR{ROANOKE, VA} MPEG4 HD TID 4575 Tp 5 SPOT 39 Ciel 2 129w UNAVAIL HIDE MAP-C 27
3 DELETE(S)
DEL 6801 UPSD MPEG2 SD Tp 5 EchoStar 5 129w UNAVAIL HIDE
DEL 6803 UP3 MPEG4 HD TID 4205 Tp 5 SPOT 16 Ciel 2 129w UNAVAIL HIDE
DEL 6866 UP29 MPEG4 HD TID 4175 Tp 5 SPOT 12 Ciel 2 129w UNAVAIL HIDE
5 MOVE(S) (May include other changes as well.)
MOVE 5180 WRTV{INDIANAPOLIS, IN} MPEG4 HD Tp 5 EchoStar 5 129w AVAIL HIDE MAP-D 6
TO 5180 WRTV{INDIANAPOLIS, IN} MPEG4 HD TID 4375 Tp 5 SPOT 24 Ciel 2 129w AVAIL HIDE MAP-D 6
MOVE 5181 WISH{INDIANAPOLIS, IN} MPEG4 HD Tp 5 EchoStar 5 129w AVAIL HIDE MAP-D 8
TO 5181 WISH{INDIANAPOLIS, IN} MPEG4 HD TID 4375 Tp 5 SPOT 24 Ciel 2 129w AVAIL HIDE MAP-D 8
MOVE 5182 WTHR{INDIANAPOLIS, IN} MPEG4 HD Tp 5 EchoStar 5 129w UNAVAIL HIDE MAP-C 13
TO 5182 WTHR{INDIANAPOLIS, IN} MPEG4 HD TID 4375 Tp 5 SPOT 24 Ciel 2 129w UNAVAIL HIDE MAP-C 13
MOVE 5183 WXIN{INDIANAPOLIS, IN} MPEG4 HD Tp 5 EchoStar 5 129w AVAIL HIDE MAP-D 59
TO 5183 WXIN{INDIANAPOLIS, IN} MPEG4 HD TID 4375 Tp 5 SPOT 24 Ciel 2 129w AVAIL HIDE MAP-D 59
MOVE 5184 WTTV{BLOOMINGTON, IN} MPEG4 HD Tp 5 EchoStar 5 129w AVAIL HIDE MAP-D 4
TO 5184 WTTV{BLOOMINGTON, IN} MPEG4 HD TID 4375 Tp 5 SPOT 24 Ciel 2 129w AVAIL HIDE MAP-D 4
TRANSPONDER CHANGES
DELETE Tp 5 EchoStar 5 129w ,QPSK SR 20000 FEC 5/6
CHANGE TID 4005 Tp 5 SPOT 1 Ciel 2 129w ,QPSK SR 20000 FEC 7/8
TO TID 4005 Tp 5 SPOT 1 Ciel 2 129w ,8PSK SR 21500 FEC 2/3
ADD TID 4375 Tp 5 SPOT 24 Ciel 2 129w 8PSK SR 21500 FEC 2/3
12 CHANGE(S) 6429 CHANNELS IN THE SYSTEM
SatelliteGuys.US DishNetwork Uplink Activity Report - 4/21/2009 2:26am - 12 changes
Uplink Comparison Range: 04/21/2009 01:58A - 04/21/2009 02:26A
Channel Additions:
5200(13) - WSET [MPEG4 HD] added to Ciel-2 129W TP 05 Spotbeam 39 (NA)(Lynchburg, VA-ABC)
5201(7) - WDBJ [MPEG4 HD] added to Ciel-2 129W TP 05 Spotbeam 39 (NA)(Roanoke, VA-CBS)
5202(10) - WSLS [MPEG4 HD] added to Ciel-2 129W TP 05 Spotbeam 39 (NA)(Roanoke, VA-NBC)
5203(27) - WFXR [MPEG4 HD] added to Ciel-2 129W TP 05 Spotbeam 39 (NA)(Roanoke, VA-FOX)
Channel Removals:
6801 - UPSD (NA) removed from EchoStar5 129W TP 05 ConUS beam
6803 - UP3 (NA) removed from Ciel-2 129W TP 05 Spotbeam 16
6866 - UP29 (NA) removed from Ciel-2 129W TP 05 Spotbeam 12
Channel Moves:
5180 - WRTV [MPEG4 HD] moved from EchoStar5 129W TP 05 ConUS beam to Ciel-2 129W TP 05 Spotbeam 24 (A) (H)(Indianapolis, IN-ABC)
5181 - WISH [MPEG4 HD] moved from EchoStar5 129W TP 05 ConUS beam to Ciel-2 129W TP 05 Spotbeam 24 (A) (H)(Indianapolis, IN-CBS)
5182 - WTHR [MPEG4 HD] moved from EchoStar5 129W TP 05 ConUS beam to Ciel-2 129W TP 05 Spotbeam 24 (NA)(Indianapolis, IN-NBC)
5183 - WXIN [MPEG4 HD] moved from EchoStar5 129W TP 05 ConUS beam to Ciel-2 129W TP 05 Spotbeam 24 (A) (H)(Indianapolis, IN-FOX)
5184 - WTTV [MPEG4 HD] moved from EchoStar5 129W TP 05 ConUS beam to Ciel-2 129W TP 05 Spotbeam 24 (A) (H)(Bloomington, IN-N/A)
Channels in the system: 6429
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
TRANSPONDER CHANGES
E5 is EchoStar 5 and it is scheduled to go to 148w to replace the now defunct EchoStar 2 and the EchoStar 1 which is scheduled to go to 77w.
TheKrell, there was a reported "Software" problem in some thread. It is not known where the problem was.
Please excuse my ignornace, but will the Johnstown-Altoona HD locals show up in the uplink activity if they are supposed to go live as expected, tomorrow on 4/22? I am keeping an eye out for my buddy who has DISH and lives in State College, PA. thanks!
Yes. You can also check at DISH Network (dishnetwork) on Twitter and sometimes if you check for available locals by zip code at the E* site, the HD locals will be listed the morning when they are scheduled to be uplinked.
I wonder if the problem was on the ground or on the satellite. My first thought was a delay in fiber to an uplink center, but the FCC docs said software problem? Perhaps they view the data stream as software and it was not going to the right uplink center.
From twitter:
Roundin out the #HDTuesday announcements for today...4 Ch.s are lighting up in #HD tomorrow 4 Johnstown-Altoona, PA (WATM, WTAJ, WJAC, WWCP)
Along w/ KKCO, beg. tomorrow, DN will be the only sat provider to carry KJCT, KREX & KFQX in #HD for Grand Junction-Montrose! #HDTuesday
First up in Joplin-Pittsburg, MO/KS...DN is the only sat provider w/ KOAM in #HD (DN Ch. 7). Begins around 5p ET *tomorrow. #HDTuesday
I still think the whole twitter thing is stupid, especially with these 10 yr olds posting on the dishnetwork one... basically just a dumbed down myspace with just comments since you only read half of the conversation. But whatever... what's the #HDTuesday mean? Is that his ID or something?
Guess normal internet forum software that has been around for years has me spoiled.
From twitter:
+1
I think it's a Tag, so if you have a twitter account you can click on the tag and it will filter out all the other stuff and just display the items with #HDTuesday in it.
They usually do this and #FollowFriday on Friday's.
INDY HD locals
Channel Additions:
Channel Removals:
Channel Moves:
Still No NBC HD local in Indy - Uplinked but NA
D
4/20/2009 3:58pm - Uplink Activity Report - 2 changes
D
4/22/2009 1:10pm - Uplink Activity Report - 55 changes
