See drawing below.
Imagine standing above the dish and looking down.
Of the curves I have drawn, black being straight, dark blue, or light blue?
The light blue curve is what you want.
See drawing below.
I vote for pointing it at 95, and see what kind of slice of the arc you get. For some reason I have a hard time seeing a 6' getting more than 6birds 2degrees apart, but then I never tried it either. Anole's math was impressive (I can barely understand a tire pressure guage lol) . Really curious to learn what the prodelin can do though, its a fine looking dish.
[FONT=Fixedsys]..
degree inch [/FONT][FONT=Fixedsys]for 6' Prodelin dish[/FONT]
[FONT=Fixedsys] orbital loc offset offset skew
74° H: +26.2° +22.95" -19.22[/FONT][FONT=Fixedsys]°[/FONT]
[FONT=Fixedsys] V: +3.0° +2.72"
79° H: +18.8° +16.75" -13.64[/FONT][FONT=Fixedsys]° [/FONT]
[FONT=Fixedsys] V: +1.4° +1.27"
83° H: +12.7° +11.4" -8.89[/FONT][FONT=Fixedsys]°[/FONT]
[FONT=Fixedsys] V: +0.6° +0.54
91° H: 0.0° 0.0" bore sight
V: 0.0° 0.0"
101° H: -15.8° -14.15" +13.21[/FONT][FONT=Fixedsys]°[/FONT]
105° H: -21.7° -19.22" +17.74[/FONT][FONT=Fixedsys]°[/FONT]
[FONT=Fixedsys] V: +2.5° +2.26"
[COLOR=Blue]107.3[/COLOR]° H: -25.0° -21.97" +[COLOR=Blue]20.21[/COLOR][/FONT][FONT=Fixedsys]°[/FONT]
[FONT=Fixedsys] V: +3.4° +3.08"
[/FONT]
Me, hung up? :yikes:If you are hung up on using that elevation gauge, you'd better calibrate it.
Maybe it's right, and maybe it's wrong, and maybe your dis-assembly of the LNB arm left you off a few degrees.
I went out and measured the bottom side of the dog leg, and it shows 45.1 degrees.I'd point you to a post I made a while back, about finding the focal point of a dish, given the mount was accurately calibrated.
But here, the question is about the calibration. . .
I'll take a look for some documents.
The mfgr's web site is full of PDFs... (see below*)
Should give the dish's offset angle, and a place to measure from, if not off a line across the face of the dish.
I believe you can put an angle finder on the lower LNB support in that short dog-leg at the bottom.
That should be the actual elevation angle of the dish.
But, that's from memory.
Let me mark-up a picture . . .
edit: added reference picture
And I would put the TS LNB at the 5 3/8th inch height.
* FindMeProdelin_1.8mDish.txt
1.2 1.8 meter dish / mesh ku offset ka rx/tx Andrew Channel Master Prodelin Solid 1 meter
http://www.gdsatcom.com/prodelin.html
My plan is to put in a 6" slot - 1/4" solid, another slot - solid, repeat to the ends of the rods.
How far out from center should I attempt my first slight bend?
What do you think so far?
[FONT=Fixedsys]..
72° H: +29.0° +25.21" -21.33[/FONT][FONT=Fixedsys]°[/FONT]
[FONT=Fixedsys] V: +3.8° +3.44"
'"[/FONT]
Thanks for your kind words.i marvel at the creativity...of course i think i might like to follow your idea, so i watch anxiously at each development. could you toss that c band lnbf w feed horn at the center to add some bud spice to the ku krazyness? kudos to the effort, and the comments of the board- especially the bend of the bar to fit focal length. wow!
Limited time offer
