OMG ! -
You know the hardware is capable.
What's with these companies??
Strike that.... The pansat 9200 does record OTA.. With the new software update fixed it from not recording OTA To doing so. I just updated to 1216
OMG ! -
It isn't that the boxes won't do it - there is no information being sent from the satellite.
Bob
I'm not too well up on it, but I think TV Guide over the air is becoming available for OTA, too.
And so I would like to see the OTA side of these FTA receivers use that.
Not sure what to use for FTA guides... but an internet link (Ethernet) and a connection to one of the internet guide data bases would sure be nice.
And, it's possible TODAY ! Just nobody has done it!
In case nobody told you, FTA satellite is something you do as a hobby, not as a all-in-one solution to your family's regular TV viewing needs. For that you really need a consumer solution like DISH or DIRECTV.What's with these companies??
Thanks, I took a look at the Coosat site to see what it did.there is a stand alone recording device that works much like the stand alone dvd recorder except that it can be easily uploaded to a pc via usb or lan or uploaded to other usb devices.
my sugestion wasn't pc based although a pc based one might be cheaper if you have the equipment ...
here's a link Coolsat CoolDirector
I understand that the FTA satellite channels do not transmit EPG data. The problem I am having is that I cannot get the program guide from local digital over-the-air stations that I pick up with a uhf antenna on my roof. I know that these stations are broadcasting EPG information since I have a GE 22730 digital converter box and it shows me a weeks worth of program guide data. My hdtv also shows me program guide data, but the pansat 9200HD does not show any guide data for over-the-air stations.
This is the way my local station are broadcasting the EPG:
Program and System Information Protocol - Wikipedia, the free encyclopedia
So there is no way the Panarex engineers can extract the program guide
data from the PSIP information stream? Thank you.
Their reply:
Unfortunately the factory is not big company like Sam Sung , LG etc, therefore they does not have good resource information of off air channel EPG.
Limited time offer
