After doing more research...
E* stated they will NEVER support PSIP except mapping of channels .
I'd like to read that, because the statement, in itself, would be a smoking gun.
Please, sight the source material.
I'm well aware of what box you're referring to .... doesn't change anything though. Gov't rules aren't going to change the way it works today. Call Dish and tell them they're non-compliant.The 722 STB I'm referring to is the larger HDD capacity unit that was made available early 2008 (possibly late 2007).
Dishnetwork's Response to 921's OTA Guide Problem!! - DBSTalk.Com
I still don't understand the rationale why can't I watch ALL the OTA channels on the 722 (the signal strength on those missing channels are excellent and I can watch them fine on the Sony KDS60A3000's built-in tunner)
Q: Are you splitting the signal (one to your 722 STB and another to your Sony)? You could experience as much as a 15db loss in signal by performing this task. I did it with my Aquos, but noticed a significant drop in signal when I did, so I dropped the splitter and went straight for the 722 RF input.
Q: On the other hand, if you're using a pre-amp or amp you could be over-modulating (over-pushing) the signal and in this case the tuner will choke.
BTW, Did you manage to see the date of that post? 12-16-04, 10:13 PM
It does not come from Dish, and someone even questions its authenticity in the string.
The provisional mandate was set back in Spring of 2006 and moves forward. Your sighting is almost a year and a half before this mandate.
The signal is splitted -3.5db, the antenna is a Larcrosse-A.
I got the signal strength from the local channel setup within the 722, the green bar is over 80, on the Sony, the signal meter shown 86, so the OTA tuner in the 722 locked on to the signals but won't add them to the guide, hence I can't tune to them with the remote or anything else that E* has.
Man, I don't know what to say... your 722 say's its happy with the signal, yet...? Does it say, "signal loss" or does the screen remain black?
I ask that, because when I switch to my local OTA PBS affiliate, and this only happens with the PBS feed (6.1, 6.2, 6.3), it takes up to 20 seconds for the signal to sync with the 722. In the meantime, I get a signal lost page. Why...? Too many factors to even begin speculating, but there's adequate signal (73 - 84). Phasing...?
vr005 - Are you saying that you can't watch OTA channels that your 722 is receiving, but are not appearing in the guide?
I thought that "non-guide" channels could still be watched. I think this issue may be peculiar to you and your particular 722, not to all users of the 722 that don't sub to Dish locals.
I don't disagree that it will come down to $$$ but I'm willing to bet, Dish will NOT "give in" because of a high number of people unsubscribing over this issue. I'd venture to say, the vast majority of customers do pay for locals and in turn get the guide data. You're in the minority here....One can only surmise the potential losses in revenue from lost subs who'll unsubscribe to locals into locals for EPG services...
Can you give links or references to this ?At present, there is an active Senate investigation into the willful withholding of mandated stream content that is also supported by the NAB. TVs and all STBs with DTV tuners as of 2007 and 2006 must provide a minimum of mandated tuner services.
But again, the Commission's rules apply to ALL TVs and STBs containing DTV tuners manufactured Spring 2006 forward.
Gotta disagree. It is obvious that Dish does it this way to get people to sub to Locals for $5 per month. It's that simple. If people with OTA reception didn't need to subscribe for the guide info, they wouldn't. Digital OTA looks way better than Dish's overly compressed local service, other than the handful of HD Locals.I don't disagree that it will come down to $$$ but I'm willing to bet, Dish will NOT "give in" because of a high number of people unsubscribing over this issue. I'd venture to say, the vast majority of customers do pay for locals and in turn get the guide data. You're in the minority here....
How many people with 622/722 receivers use an antenna ? I still say the minority....Gotta disagree. It is obvious that Dish does it this way to get people to sub to Locals for $5 per month. It's that simple. If people with OTA reception didn't need to subscribe for the guide info, they wouldn't. Digital OTA looks way better than Dish's overly compressed local service, other than the handful of HD Locals.
Limited time offer
