New Software Updates thread | Page 2 | SatelliteGuys.US
PID: 08B1h, ID: 29KC, FW: L443, Model: ViP622/ViP722
Mon Sep 10 23:19:54 2007
DownloadID:'29KC'
Upgrading FW:
'L443': 'ABA1'- 'BYE1' 'L040'- 'L442'
New FW:'L443'
List of BootStraps and BuildConfigs:
'1[3-8]1[AB0-6]' 'RB[BDEGHK-NP][A-DJ]'
IRD Model: ViP622
List of Serial Numbers:
[2] 1-4000000000
'1[3-8]1[ABE0-7]' 'RJ[KLNP-X][A-DJ]'
IRD Model: ViP722
[2] 1-4000000000
yup... I checked this morning and I have 443 on my 622 now. Now I have to search threads to see what, exactly, it means to me. :) All I remember is the ability to sort recordings by time or by alphabetically. Beyond that.... I'm not quite sure what all else I should be seeing.
Found 'em using search (funny how that works, huh?), but thanks. Having the release notes link right after teh post about everybody getting 443 will almost surely be helpful for a lot of folks.
That would be nice; I've been stuck at L3.45 even though the Dish CSR told me two months ago that new software would fix my ViP211...:rolleyes:
L3.49 broke my 211. I can't use the HDMI port anymore. :mad:
There's a lot activity for beta software. They're testing software for the:
501, 811, 522/625, 622/722, and 222 receivers.
Looks like we should get some activity tonight:
9/17/2007: 1546 Software Version L4.33 for ViP 211/DISH 411
Effective Tuesday, September 18th, Engineering plans to spool a PARTIAL PHASE of software version L4.33 for the ViP 211/DISH 411 receiver. This is primarily a non-forced maintenance release available at ALL satellite locations.
At this time L3.45, L3.49, L4.30, and L4.33 will be the valid software versions for the ViP 211/DISH 411.
9/17/2007: 1545 Software Version P4.00 for DP501/508/510
Effective Tuesday, September 18th, Engineering plans to spool a PARTIAL PHASE of software version P4.00 for the DP501/508/510 receiver. This is primarily a non-forced maintenance release available at ALL satellite locations.
At this time P3.69 and P4.00 will be the valid software versions for the DP501/508/510.
PID: 08B3h, ID: 1GAC, FW: L433, Model: ViP211/ViP211
Mon Sep 17 23:29:35 2007
Upgrading FW:
'L433': 'L349'- 'L430'
'NONE': 'L349'- 'L430'
New FW:'L433'
'1[01]1[A-D0-4]' 'RA[CDFGJKMPRTV-Z2-46-8][A-DJ]'
IRD Model: ViP211
[2] 70565979-74899432
Software Update for the 322 and 351 receivers.
PID: 0890h, ID: 5NZD, FW: L422, Model: DP322/DP322
PID: 08A3h, ID: 0RMD, FW: P373, Model: D351.
Tue Sep 18 23:21:35 2007
New FW:'L422'
'1[3-6D]1[0-7ABF]' 'GC[BCE-HJ-NPQ][A-DJ]'
IRD Model: DP322
[2] 1-4000000000
'1[4-6]1[0-7F]' 'GD[A-DHJ-LNP-X][A-DJ]'
IRD Model: DP322
[2] 1-4000000000
DownloadID:'0RMD'
New FW:'P373'
Upgrading FW:'AAA1'-'BAB1','P050'-'P372'. [27/27]
IRD Model: D351
List of BootStraps, BuildConfigs and Serial Numbers:
101C LBBA - 1012 LBDD [2] 1-4000000000
PID: 0861h, ID: 78SD, FW: P400, Model: PVR5xx.
Tue Sep 18 23:27:09 2007
DownloadID:'78SD'
New FW:'P400'
Upgrading FW:'AAA1'-'DAS1','P050'-'P368'. [587/224]
IRD Model: PVR5xx
10KB DCDA - 19CB DCZD [2] 1-4000000000
PID: 0891h, ID: 71XD, FW: L461, Model: DVR522/DVR625
PID: 08B0h, ID: 1FAC, FW: L433, Model: ViP211
Wed Sep 19 23:42:06 2007
Upgrading FW:
'L461': 'AAA1'- 'DVF1' 'L058'- 'L460'
'NONE': 'AAA1'- 'DVF1' 'L058'- 'L460'
'1417': '1[34]1[0-6]'
'AAA1'- 'DVF1' 'L058'- 'L461'
New FW:'L461'
'1[34]1[0-7]' 'GA[E-HJ-LNPQST][A-DJ]'
IRD Model: DVR522
[2] 1-4000000000
'1[34]1[0-7]' 'GJ[A-HJ-NP-Z2-4][A-DJ]'
IRD Model: DVR625
[2] 1-4000000000
Upgrading FW:
'L433': 'AAA1'- 'BKD1' 'L040'- 'L099' 'L349'- 'L349' 'L430'- 'L430'
'NONE': 'AAA1'- 'BKD1' 'L040'- 'L099' 'L349'- 'L349' 'L430'- 'L430'
'1113': '1[01]1[A-D0-2]'
'AAA1'- 'BKD1' 'L040'- 'L099' 'L349'- 'L349' 'L430'- 'L430' 'L433'- 'L433'
New FW:'L433'
'1[01]1[A-D0-3]' 'RA[CDFGJKMPRTV-Z][A-DJ]'
IRD Model: ViP211
[2] 1-4000000000
For the 211 receivers, all receivers except the ones with L3.45 will get L4.33. L3.45 and L4.33 will be the only two updates out there.
Upgrading FW:
New FW:'L461'
IRD Model: DVR522
[2] 1-4000000000
IRD Model: DVR625
[2] 1-4000000000
Upgrading FW:
New FW:'L433'
IRD Model: ViP211
[2] 1-4000000000
I have problem with HDMI. 480p scale is OK anything higher is a problem, no picture. Dish just roll out the new software for 211 (L433). I still can not download new software into my 211. My 211 still showing 430. Anybody, how we I download new software. I try soft/hard reboot many times yesterday and this morning. I will try again tonight and post update soon. Yes, my 211 is turn OFF/ Plug in.
Did you run check switch? Menu, 6, 1, 1, Check Switch.
L4.33 fixed my HDMI problem with the 211.
Randall. OK. I got L4.33 on the 211 tonight. I changed the HDTV aspect to 720p and 1080i. Well, rats for about 5 mins. of viewing 1080i, man I was so excite, but only working for 5 mins. It' been turning my TV off and on. I did many times soft and hard reboot. Same problem. My panny project wants to accept 1080i, but looks like not enough strong signal. I tried all handshakes and same problem. One thing I notice when I went into HDMI Analyses.I notice the HDMI is ON, Color Span is RGB and HDCP Enable is now turn ON. With l430 software, HDCP enable was turn OFF. I now leaving the HD box unplug for 30 mins. I'll be back for update soon. I you know what is going on based on my problem described, please help. I'm running out of patient with Dish. I will also email them right now. Regards Thanks.
Not much you can do about it except to run component cables, it sucks but that's the only thing you can do. Email them so hopefully they can get it right but don't expect much resolution on this issue. They fix one thing and break another one.
They fixed my OTA problem but they broke my HDMI connection with the last software update. It looks like they fixed my issue with this new one but I know several people that are still having problems with the HDMI port on the 211s.
One more thing, some people have suggested the use of an HDMI switch. Don't know exactly how that would fix the problem but you may want to do a search.
Hey thanks for the quick respond. I know for a fact it's not the hardware. I got it to work in 1080i for 5mins. When I installed my projector in the ceiling mount. I only ran 35ft HDMI. I wasn't thinking a back plan to also run component cable. Anyway, learn my lesson. Also, I do have 4x1 hdmi switch box from MONOPRICE.com works great for game and other dvd players. If Dish roll new software like this L433. Does it has to be in the HD box for a period of time for HD box to acquire everything before HD signal can all work right?
It should work right away. A reboot after a software update is always recommended.
PID: 0867h, ID: 79SD, FW: P400, Model: PVR5xx.
Mon Sep 24 23:25:38 2007
New FW:'P400'
Upgrading FW:'DAS1'-'DAS1','P369'-'P369'. [157/157]
IRD Model: PVR5xx
23AB DCDA [2] 55990248-56115994
23AB DCDD [2] 55990248-56115994
23AB DCEA [2] 55990248-56115994
23AB DCED [2] 55990248-56115994
23AB DCFA [2] 55990248-56115994
23AB DCFD [2] 55990248-56115994
23AB DCKA [2] 55990248-56115994
23AB DCKD [2] 55990248-56115994
23AB DCMA [2] 55990248-56115994
23AB DCMD [2] 55990248-56115994
23AB DCNA [2] 55990248-56115994
23AB DCND [2] 55990248-56115994
23AB DCPA [2] 55990248-56115994
23AB DCPD [2] 55990248-56115994
23AB DCSA [2] 55990248-56115994
23AB DCSD [2] 55990248-56115994
23AB DCTA [2] 55990248-56115994
23AB DCTD [2] 55990248-56115994
23AB DCUA [2] 55990248-56115994
23AB DCUD [2] 55990248-56115994
23AB DCVA [2] 55990248-56115994
23AB DCVD [2] 55990248-56115994
23AB DCWA [2] 55990248-56115994
23AB DCWD [2] 55990248-56115994
23AB DCXA [2] 55990248-56115994
23AB DCXD [2] 55990248-56115994
23AB DCYA [2] 55990248-56115994
23AB DCYD [2] 55990248-56115994
23AB DCZA [2] 55990248-56115994
23AB DCZD [2] 55990248-56115994
23AB DC2A [2] 55990248-56115994
23AB DC2D [2] 55990248-56115994
23AB DC3A [2] 55990248-56115994
23AB DC3D [2] 55990248-56115994
23AB DC6A [2] 55990248-56115994
23AB DC6D [2] 55990248-56115994
23AB DC7A [2] 55990248-56115994
23AB DC7D [2] 55990248-56115994
23AB DC8A [2] 55990248-56115994
23AB DC8D [2] 55990248-56115994
23AB DFAA [2] 55990248-56115994
23AB DFAB [2] 55990248-56115994
23AB DFAD [2] 55990248-56115994
23AB DFBA [2] 55990248-56115994
23AB DFBB [2] 55990248-56115994
23AB DFBD [2] 55990248-56115994
23AB DFCA [2] 55990248-56115994
23AB DFCB [2] 55990248-56115994
23AB DFCD [2] 55990248-56115994
23AB DFDA [2] 55990248-56115994
23AB DFDB [2] 55990248-56115994
23AB DFDD [2] 55990248-56115994
23AB DFEA [2] 55990248-56115994
23AB DFEB [2] 55990248-56115994
23AB DFED [2] 55990248-56115994
23AB DFFA [2] 55990248-56115994
23AB DFFB [2] 55990248-56115994
23AB DFFD [2] 55990248-56115994
23AB DFGA [2] 55990248-56115994
23AB DFGB [2] 55990248-56115994
23AB DFGD [2] 55990248-56115994
23AB DFHA [2] 55990248-56115994
23AB DFHB [2] 55990248-56115994
23AB DFHD [2] 55990248-56115994
23AB DFJA [2] 55990248-56115994
23AB DFJB [2] 55990248-56115994
23AB DFJD [2] 55990248-56115994
23AB DFKA [2] 55990248-56115994
23AB DFKB [2] 55990248-56115994
23AB DFKD [2] 55990248-56115994
23AB DFLA [2] 55990248-56115994
23AB DFLB [2] 55990248-56115994
23AB DFLD [2] 55990248-56115994
23AB DFMA [2] 55990248-56115994
23AB DFMB [2] 55990248-56115994
23AB DFMD [2] 55990248-56115994
23AB DCXV [2] 55990248-56115994
24AB DCDA [2] 55990248-56115994
24AB DCDD [2] 55990248-56115994
24AB DCEA [2] 55990248-56115994
24AB DCED [2] 55990248-56115994
24AB DCFA [2] 55990248-56115994
24AB DCFD [2] 55990248-56115994
24AB DCKA [2] 55990248-56115994
24AB DCKD [2] 55990248-56115994
24AB DCMA [2] 55990248-56115994
24AB DCMD [2] 55990248-56115994
24AB DCNA [2] 55990248-56115994
24AB DCND [2] 55990248-56115994
24AB DCPA [2] 55990248-56115994
24AB DCPD [2] 55990248-56115994
24AB DCSA [2] 55990248-56115994
24AB DCSD [2] 55990248-56115994
24AB DCTA [2] 55990248-56115994
24AB DCTD [2] 55990248-56115994
24AB DCUA [2] 55990248-56115994
24AB DCUD [2] 55990248-56115994
24AB DCVA [2] 55990248-56115994
24AB DCVD [2] 55990248-56115994
24AB DCWA [2] 55990248-56115994
24AB DCWD [2] 55990248-56115994
24AB DCXA [2] 55990248-56115994
24AB DCXD [2] 55990248-56115994
24AB DCYA [2] 55990248-56115994
24AB DCYD [2] 55990248-56115994
24AB DCZA [2] 55990248-56115994
24AB DCZD [2] 55990248-56115994
24AB DC2A [2] 55990248-56115994
24AB DC2D [2] 55990248-56115994
24AB DC3A [2] 55990248-56115994
24AB DC3D [2] 55990248-56115994
24AB DC6A [2] 55990248-56115994
24AB DC6D [2] 55990248-56115994
24AB DC7A [2] 55990248-56115994
24AB DC7D [2] 55990248-56115994
24AB DC8A [2] 55990248-56115994
24AB DC8D [2] 55990248-56115994
24AB DFAA [2] 55990248-56115994
24AB DFAB [2] 55990248-56115994
24AB DFAD [2] 55990248-56115994
24AB DFBA [2] 55990248-56115994
24AB DFBB [2] 55990248-56115994
24AB DFBD [2] 55990248-56115994
24AB DFCA [2] 55990248-56115994
24AB DFCB [2] 55990248-56115994
24AB DFCD [2] 55990248-56115994
24AB DFDA [2] 55990248-56115994
24AB DFDB [2] 55990248-56115994
24AB DFDD [2] 55990248-56115994
24AB DFEA [2] 55990248-56115994
24AB DFEB [2] 55990248-56115994
24AB DFED [2] 55990248-56115994
24AB DFFA [2] 55990248-56115994
24AB DFFB [2] 55990248-56115994
24AB DFFD [2] 55990248-56115994
24AB DFGA [2] 55990248-56115994
24AB DFGB [2] 55990248-56115994
24AB DFGD [2] 55990248-56115994
24AB DFHA [2] 55990248-56115994
24AB DFHB [2] 55990248-56115994
24AB DFHD [2] 55990248-56115994
24AB DFJA [2] 55990248-56115994
24AB DFJB [2] 55990248-56115994
24AB DFJD [2] 55990248-56115994
24AB DFKA [2] 55990248-56115994
24AB DFKB [2] 55990248-56115994
24AB DFKD [2] 55990248-56115994
24AB DFLA [2] 55990248-56115994
24AB DFLB [2] 55990248-56115994
24AB DFLD [2] 55990248-56115994
24AB DFMA [2] 55990248-56115994
24AB DFMB [2] 55990248-56115994
24AB DFMD [2] 55990248-56115994
24AB DCXV [2] 55990248-56115994
PID: 08B3h, ID: 1JAC, FW: L431, Model: ViP211
Upgrading FW:
'L431': 'L345'
'NONE': 'L345'
New FW:'L431'
'1[01]1[A-D0-3]' 'RA[CDFGJKMPRTV-Z2-46-8][A-DJ]'
IRD Model: ViP211
[2] 1-4000000000
722 and 722k
